How much Compression? should be between 165lbs to 185lbs per cyclinder. Sea Foam the gas to help clear carbs out of old gas and varnish, see if that helps, kinda sounds like its a problem with the carbs if you have everything else working ok. Sea Foam really works great, just ad to gas one can per 10 gallons, use in car and lawn mower also, and great in weed eaters. You can also look at your reed valves too could be chipped or broken?
Good luck hope it helps.
-- Confucius
