95 900 zxi not cooling - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-22-2009, 05:38 PM   #1 (permalink)
Default 95 900 zxi not cooling
First time out it ran great for a couple minutes, then would only idle. Temp light flashed and I noticed not water pumping out at all. Blew through the tubes on both ends and doesn't appear to have any clogs. Where do I start??? Any suggestions.
Jerry is offline   Reply With Quote
Old 06-22-2009, 10:09 PM   #2 (permalink)
JayDawg's Avatar
Check the route the water takes through the motor and exhaust and see if there is any debree in there at all.
1996 Kawasaki 750 SXI
1999 Kawasaki Ultra 150
www.quadsforchrist.net
Old 06-23-2009, 07:05 PM   #3 (permalink)
I checked all the tubes everything is clear. Air flows through with ease, any other suggestions?
Old 06-24-2009, 12:14 AM   #4 (permalink)
JayDawg's Avatar
Don't check it with air, check it with water such as a garden hose while you engine is running. If the water doesn't come out of your exhaust, pee hole on the side and jet nozzle, then you have a blockage somewhere.
Old 06-25-2009, 02:48 PM   #5 (permalink)
I did that already and water was flowing fine out the side port and the rear discharge. I hope what ever was in there is now out. But I won't know till I drop it in the water. Thanks for the help...let you know how it goes.
