What's in the performance package? I have never even heard of that before? The choke should only be used until that engine is warm enough to idle on it's own. Actually, on my Ultra 150, I use it just to get it started and then it is good from there. With your trim, it does not matter what position it is in for riding. If my memory serves me correctly though. If I want to go fast in a straight line, I put my trim up. If I want to do more turning and have it corner better, I put the trim down. With the one that is only going 20 mph at full throttle, try changing out the spark plugs first. That is the cheapest fix and is the problem many times. If it is not that, then check your impeller and drive shaft for damage. They can be seen from underneath your boat through the intake grate at the rear of the jet ski. If those are all good, then check your engine compression. As far as how many gallons of fuel to ounces of oil that you use, that is a good question? If I have a full thing of oil it will usually last me 4-6 tanks of fuel. Going off of memory, I know my fuel tank is 15-15.5 gallons of fuel and I believe my oil tank is approximately 1 gallon but I could be wrong on that but I do know it is somewhere around that capacity.
