You should have a Flush T on the top of the engine to plug a water hose to, so that you can flush out the engine. I would also look back in the prop area, and make sure that all your hoses are connected from the pump that feed back into the ski, could be as simple as a hose comming undone. check to make sure this isn't anything blocked also inside the pump area, if you look into the nozzel on the right side you will see a hole where the pressure feeds the hose that cools the engine, make sure its clear. Make sure you have the engine running FIRST before turning on the water to flush. Also check all your hoses inside the engine compartment, make sure one of them have not come undone, with the age of the ski this can be a possiblility . Good Luck.
-- Confucius
