1995 750 SS XI NO Spark?? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-06-2009, 04:17 PM   #1 (permalink)
Default 1995 750 SS XI NO Spark??
95 750ss xi runnng great for a couple hours suddenly stop in the water.
checked the plugs looked good getting fuel , checked for spark no spark. the fuse is good. I never worked on a jet ski before so i dont know where the coils or what is, so can anyone help. I am very familiar with autos but no skis any help to fix spark probleom?
tonyp2001 is offline   Reply With Quote
Old 07-06-2009, 05:43 PM   #2 (permalink)
glockm22's Avatar
New Jet Ski Parts and Used Jetski Parts - Jetskiparts.com Go to this website, and plug in your information on the ski its simple, and it will give you a parts breakdown of your Ignition system, and the park #'s and pricing.
My guess is that the coil has gone bad? Hopefully not the Igniter, because their spendy. but if your fimilar with cars you can ohms test and do your voltage testing and be able to figure it out. Good Luck, please post what you come up with.
-- Confucius
Old 07-06-2009, 06:02 PM   #3 (permalink)
thanks ill try it out.
Old 07-06-2009, 07:45 PM   #4 (permalink)
I tried starting it today give a hint that almost starts then no more just for that one second then wont spark again.
Old 07-06-2009, 11:24 PM   #5 (permalink)
it was a kill switch problem with my 97ss would only spark with lanyard in one spot.
i took the switch box apart and get plenty off spark
danhuffmans is offline   Reply With Quote
Old 07-07-2009, 01:51 PM   #6 (permalink)
when you took ur kill switch apart what u supposed to do to fix? What can be broken?
Old 07-07-2009, 02:42 PM   #7 (permalink)
glockm22's Avatar
Good job! Thanks for posting, I'll keep that one in mind, pretty easy fix, didn't think to check their.
-- Confucius
Old 07-07-2009, 04:50 PM   #8 (permalink)
took electrical box out to test coil and it seems to ohm out to .05 beep so what else should i check? is there a way to check the ignitor or stator?
Old 07-07-2009, 08:45 PM   #9 (permalink)
Haven't figured out why this is happening but sometimes i get spark and sometimes i don't. When i do it,s strong. Makes me throw the plug and wire. So i am ordering a new switch looks like a sealed deal. Yesterday it started fine this afternoon no start this eveing fired right up. With my problem i dont see the coil working so intermintly. i'm open to any other ideas
Old 08-05-2009, 08:52 PM   #10 (permalink)
Default Same problem as tonyp2001
My '96 Kawa 750 ssxi has no fire. Have tried everything including taking kill switch apart, checked all fuses, etc. I am not very mechanical so any help is appreciated. Any ideas?
PatrickKawi is offline   Reply With Quote
