900 zxi problems need help!!! please - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-14-2009, 12:11 PM   #1 (permalink)
Default 900 zxi problems need help!!! please
first it wouldnt max rev so i checked the plugs the carbs the exhaust manifold . . . it turned out to be the gas cap was broken . . .
fixed that and now there is alot of fuel in the #1 cylinder ...when i take plugs out to blow it out its like there is little fuel in the #2 and #3 and to much in the #1 any ideas or suggestions ?
Jamesad77 is offline   Reply With Quote
Old 07-19-2009, 06:36 PM   #2 (permalink)
make sure that u have spark in that cylinder and that it is firing and and u r not flooding the cylinder that way. if not do a rebuild on the carbs, carb kits r cheep.
redneckjeep40 is offline   Reply With Quote
Old 07-21-2009, 03:04 PM   #3 (permalink)
glockm22's Avatar
sounding like carbs are your problem, mabye a bad or clogged seat. rebuild carbs, and do a compression test on each cycl. check spark at each cycl also.
-- Confucius
Old 07-22-2009, 07:49 PM   #4 (permalink)
the broken gas cap has nothing to do with your problem. the gas tank is not a sealed system or your tank would suck itself in when you ran your engine and pulled fuel from it
danhuffmans is offline   Reply With Quote
