sorry this a newb question - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-24-2009, 09:15 AM   #1 (permalink)
Default sorry this a newb question
So just getting into jet skis this year i recently picked up a 87 js550 FOR $300 runs like a charm, and i also picked up 93 750ss i was just wondering if the fuel and oil lines need to be primed b4 running the engine. I had the engine started but its not getting fuel from the tank, is there a fuel pump on these things? lol im used to dirtbikes where gravity does the job. So ne one who has ne pointers it would be greatly appreciated.
rhett1366 is offline   Reply With Quote
Old 07-27-2009, 02:40 PM   #2 (permalink)
JayDawg's Avatar
I believe there is a pump in the tank but could be wrong as it has been years since I have seen one of those ski's. If it does have a pump in the tank, then it is probably bad.
1996 Kawasaki 750 SXI
1999 Kawasaki Ultra 150
www.quadsforchrist.net
Old 07-27-2009, 11:27 PM   #3 (permalink)
does ne one know if there is a pump in the tank? and what is the purpose of the case pump on the carb?
Old 08-02-2009, 11:11 PM   #4 (permalink)
I don't know of any Kawi stand up that has a pump in the tank. They all have a pump integral to the carb.
One trick you can try is blowing in the vent line.... It has a one way check valve and by blowing in it you slightly pressurize the tank and there's no risk of drinking any fuel.
If you pull the fuel line from the carb you can push fuel through the system and clear the old fuel from your lines using this technique.
15f pilot is offline   Reply With Quote
