Kawasaki 750 Over heating - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-05-2009, 08:28 AM   #1 (permalink)
Default Kawasaki 750 Over heating
Hello All,
I have a 1996 Kawasaki with the 750 motor. I have recently removed the oil injection pump due to the oil lines starting to fail. It was removed lines capped, block off plate installed, and fuel pre-mixed. No problems since. While out on the water this past weekend the ski began to pee less and less water. We turned and headed back towards the dock as soon as we noticed it. Under higher RPMs it would pee better but not as it should. We were not operating in shallow water and I checked the inlet area and could not find any reason to believe it sucked up any debris. The water temp sensor was by passed by the previous owner but I am sure it overheated due to the color of the motor and becuase some of the plastic coating on a wire was starting to melt.
My first question is does any one know of any common problems with these motors that do not allow water to properly flow through it?
I have not had a chance to put a compression guage on the motor yet but I feel confident that it is now way below par just because of the way it sounds when I turn the motor over. It will try and crank with a little starting fluid put will not run.
So my second question is after a over heat like this what are the common parts that must be changed or checked?
Thanks for your help.
jmkratz18 is offline   Reply With Quote
Old 08-12-2009, 01:23 PM   #2 (permalink)
Nobody has any ideas?
Old 08-19-2009, 01:51 PM   #3 (permalink)
i did the same thing with my yamaha it had a blockage ran it to the dock and knocked out the rings. do a compression test bet the come up short. need to bore the cylinder and put new piston and rings in as long as the crank bearing feel ok
redneckjeep40 is offline   Reply With Quote
Old 08-19-2009, 03:25 PM   #4 (permalink)
speedfreak99's Avatar
check the hose going to the pump housing- it might have worn, got bent or clogged- your going to need to drop the ride plate- it happened to one of my x2's when I changed the pump to one with a diferent eblow and ended up bending the hose- compression test and you might be ok with some new rings! good luck
speedfreak99 is offline   Reply With Quote
Old 08-20-2009, 12:59 PM   #5 (permalink)
Thanks for the help. I am going to start with the compression check and then onto breaking it down after that.
