Kawasaki 750ss, bogging, losing power problems
Ok, this is boggling my mind so I am asking for help please. I have a 95 750ss in good condition. good compression, starts first time every time, no problems. We took it out for the first time and drove it around and had a blast and then let it sit in the 100 degree Florida sun. I went to take it out and it fired right up, then after I got passed the shallow area, gave it some gas and it bogged down, the whole ski shook, and I didn't go anywhere no mater how I worked the throttle.
we towed it home and flushed it, and then after 2 hours it worked again, and I took it home and found that the temp sensor was plugged up. I cleared it and took off all the cooling lines and cleaned them, now all the cooling is cleared and it pees 1 inch at idle and 3 to 4 at WOT.
Today after replacing the plugs, which looked good, no oil, or anything else on them but carbon, and running some sea foam in the tank I took it out again, and after running it for 20 min, the same situation. The motor wont go, and it shakes, its still peeing, and the motor never stalls, so I can idle back home, but nothing else. And it still starts right away
Any Ideas?
