2000 Kawasaki Jet Ski 1100 stx w/ check engine light on - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-18-2009, 07:42 PM   #1 (permalink)
Default 2000 Kawasaki Jet Ski 1100 stx w/ check engine light on
I've got a 2000 Kawasaki 1100 stx di that I purchased a few months ago. It's run fine until this weekend. I ran it for about 10 minutes and the check engine signal came on and the warning light was flashing. It wouldn't go over 4,000 rpm. I got back to shore and turned it of and let it sit for 30 minutes. I started it and rode it for around 5 minutes fine and then the check engine came on again. I repeated this around 5 times with the same result. I checked the Kawasaki website and ran the vin and it has a recall for the fuel tank vent hose and fuel hose replacement. Could this be the issue? If anyone knows what's going on with it any feed back would be greatly appreciated!
Texashookem is offline   Reply With Quote
Old 08-19-2009, 09:40 AM   #2 (permalink)
speedfreak99's Avatar
I just had the same problem and then my number 1 cylinder seized up about two miles from the boat launch- I got it unseized and putted to the launch- let it cool down and it ran pretty good for a few minutes till it got warm- Better do a compression test- if you don't have a tester go down to autozone and get one for about 15 bucks
speedfreak99 is offline   Reply With Quote
Old 11-29-2009, 07:17 PM   #3 (permalink)
Check your oil. If it is low, the pwc will go into idle mode. This happened to mine.
jamesbardwil is offline   Reply With Quote
Old 06-07-2011, 03:42 PM   #4 (permalink)
Cool Kawasaki stx 1100 Check engine
I have had the same problem with my 2001 Kawasaki stx 1100. After about 10 minutes of running, the check engine light comes on and it goes into LIMP mode. After sitting awhile it runs fine again for about 10 minutes. I have had it to three shops and they can't solve the problem because they don't have a way to run it at speed until the warning light comes on. The shops say it runs fine. ANY ONE SOLVED THIS PROBLEM BEFORE ??
lwsumrall is offline   Reply With Quote
