New Plans
Ok, so heres the new plan. I found a hull from a 1996 750 zxi. I still have the 1994 750 ss with the cracked hull. I was told the engine will be a direct swap but the pump may not be compatible. I am wondering if the pump itself, the nozzle, or both may or may not work. If anyone knows for sure, or knows what I need if they arent compatible that would be a good place for me to start. Thanks in advance for any advice!
