90 Js550 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-17-2009, 03:16 PM   #1 (permalink)
Default 90 Js550
So I bought a JS550 had to replace the crank seals. But a piece on the stator plate broke we tighten it down as hard as we could. We got it to start right away. Then it died after 10 secs. Fuel is going to the carb. Now it turns over but wont fire. Getting spark from both spark plugs. Could it be the stator? Any suggestions?
xposed719 is offline   Reply With Quote
Old 09-24-2009, 08:57 PM   #2 (permalink)
no fear here's Avatar
If as you say there is both spark and fuel, you may have a timing issue.
I read that it started for about 10 seconds, then died. I will also assume that you tried priming and it still didn't start. It has been known to happen that the woodruf key that locates the flywheel will shear and allow the flywheel to turn slightly on the crankshaft changing the timing enough that it wont start.
You will still have fuel, and great spark, but it won't start.
There is an awesome thread in vintage that describes how to check and properly time the 550's
Hope this helps.
PJS Exhaust & Waterbox
38mm Keihin
R&D Reeds, Cages & Stuffers
Skat 15
R&D Toploader Scoopgrate
Ocean Pro rideplate
Pump drilled for dual cooling
500gph rule
Old 09-24-2009, 11:08 PM   #3 (permalink)
Hey thanks for the response. Got it running was just flooded severely.
