Newbie on the search(info 1990 550sx) - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 10-04-2009, 06:22 PM   #1 (permalink)
Default Newbie on the search(info 1990 550sx)
Runs good. But only until the battery runs out of life. machine won't keep battery charged. Would like to know where to start.
Pbigbore is offline   Reply With Quote
Old 10-05-2009, 05:34 PM   #2 (permalink)
no fear here's Avatar
It probably has an aftermarket "Total Loss" ignition system. In otherwords there is no charging coil on the stator assembly. If it doesn't have a total loss system then the charging coil is probably bad and needs to be replaced.
PJS Exhaust & Waterbox
38mm Keihin
R&D Reeds, Cages & Stuffers
Skat 15
R&D Toploader Scoopgrate
Ocean Pro rideplate
Pump drilled for dual cooling
500gph rule
