problem with plugs 2001 stx di 1100 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 04-27-2010, 07:31 PM   #1 (permalink)
Default problem with plugs 2001 stx di 1100
ok i have a 2001 stx di 1100. thought i may have a problem with one if the injectors.... but i was told by my mechanic to get new plugs and move the fuel injector from cylinder 3 and move it to another cylinder and see if just that one injector is messed up or it is the computer not sending correct info to the 3rd cylinder. I went for a test run today with new plugs 30min later i came back flushed the engine and all the plugs were fouled up.
Mention to note during my ride the oil light came on. oil display showed 3/4 then to 1/4 and that is when the light cam on after a min it went back to 3/4.
during flushing i looked and the oil tank is about 1/4 if not less.....
So back to the original question is there something i should look for if all the plugs are being fouled... being gas to oil mix not being correct... too much gas or too much oil?
need help
kbooth is offline   Reply With Quote
