These skis dont have any water filtration on them. Any small amout of debris could stop them up. Does your ski have a water bypass on it. That would be a jet on the exterior of the ski that squirts water while the engine is running.On both of my ski's they are on the left side while riding.If not,it would be a good idea to install one so you can monitor water flow. If you have an air compressor you can blow out the lines.Disconnect the water supply line from the inside of the engine compartment going to the engine. Blow air thru that line and check for debris(My 550sx got hot and was leaves stopping the supply line)Then blow out the lines on the engine and check the fiitings for blockage. You might be able to find the cylinders fairly cheap on ebay
If you want to sit down,stay on the beach!...Stand ups for life!
