Put it back together and remove the spark plugs.Turn the engine by hand and see if you fell anything dragging. If not it could be your starter.Take it out and hook a battery to it and see if its making the same noises.The starter make not be jumping out as far as should.Look at the teeth on the flywheel and see if they look chewed up from the starter.
If you want to sit down,stay on the beach!...Stand ups for life!
