89 Kawasaki TS Oil Fill? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-18-2010, 09:05 AM   #1 (permalink)
Default 89 Kawasaki TS Oil Fill?
I picked up a TS in excellent shape over the winter. I was going over everything and noticed a oil fill cap on the front of the engine. What is that for??
I know, I need to buy a repair manual, just haven't needed it yet.
Thanks!
ghlacy is offline   Reply With Quote
Old 05-18-2010, 07:22 PM   #2 (permalink)
I truly don't mean to insult you with this answer, so no offense intended with this answer (please tell me if I'm missing what you're asking)... that oil fill cap is to put your 2-cycle oil into the oil tank. The motor in this jet ski is a 2-cycle motor which means it burns a gas/oil mix when it runs. Without the oil, you will burn out your engine -- fast. The oil pump and carburetor mix it for you while the engine runs, but you need to have oil in that tank along with gas in your gas tank if you want it to run.
dvanpham is offline   Reply With Quote
Old 05-18-2010, 10:21 PM   #3 (permalink)
Right I understand that. This ski is not oil injected. I have to pre-mix the oil with the gas. This is located on the front of the engine. Here are some pictures.
Old 05-18-2010, 11:18 PM   #4 (permalink)
Ignition timing cap -- see the part labeled B in this drawing -- Ronayers.com Fiche Desktop Personal Watercraft Kawasaki 1990 TS Hull Fittings(1/2)
Old 05-19-2010, 06:37 AM   #5 (permalink)
THANKS!!
Old 05-19-2010, 05:29 PM   #6 (permalink)
no fear here's Avatar
Don't put oil in there. You will fry the stator if you do.
PJS Exhaust & Waterbox
38mm Keihin
R&D Reeds, Cages & Stuffers
Skat 15
R&D Toploader Scoopgrate
Ocean Pro rideplate
Pump drilled for dual cooling
500gph rule
