1990 Kawasaki 550sx.. What is seized?! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-01-2010, 02:02 PM   #1 (permalink)
Default 1990 Kawasaki 550sx.. What is seized?!
Last labor day, my ski was running like a champ all day. Towards the end of the last day I hopped on it and it started, then after a few moments it slowed and died. After that it only clicks like it is trying to start but doesn't do anything. I've pulled the starter and it seams to be working fine. I saw somewhere that I should pull the plugs and try to rotate the shaft manually. I tried this and I can't get it to turn. What is the best way to diagnose what is seized up?
Thanks!
Carl Don
CarlDon550sx is offline   Reply With Quote
Old 06-03-2010, 07:01 AM   #2 (permalink)
Outlaw's Avatar
Hey carl more than likely you locked up motor. More than likely you are looking at new pistons and at least honing the cylinders. Is your ski 2 stroke if so, you may have a bad injector pump for your oil. I fit is premix maybe the mixture was off. But by the sounds of the way it died off it is piston lock. good luck.
Old 06-03-2010, 07:00 PM   #3 (permalink)
cantgetright's Avatar
I would pull the engine and rotate by hand if possible before blaming the engine. Your pump housing bearings could of froze up.
If you want to sit down,stay on the beach!...Stand ups for life!
cantgetright is offline   Reply With Quote
Old 06-04-2010, 11:11 AM   #4 (permalink)
Yeah I was trying to think of anything else that could be the problem before the engine because it was running perfect all day long. I'll check both issues soon and let you know what comes of it. Let me know if you come up with anything else to check on. Thanks guys.
Old 07-12-2010, 10:48 PM   #5 (permalink)
did you suck a rock into the impeller?
premis is offline   Reply With Quote
