91 kawasaki 650sx running problems - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-01-2010, 08:05 PM   #1 (permalink)
Default 91 kawasaki 650sx running problems
my 91 650 won't go past 1/8th throttle. it starts shaking and bogging. i checked the carburetor, the reeds, the stator as well as the cdi. i don't know what else the problem could be it runs out of the water after adjusting the carb then when it gets in the water it takes off for about 50 ft and then goes back to the same way it was running before. any ideas would be a great help. thanks
rideyz102 is offline   Reply With Quote
Old 06-03-2010, 07:10 PM   #2 (permalink)
cantgetright's Avatar
could have a week spark.Oil mix might be off?
If you want to sit down,stay on the beach!...Stand ups for life!
cantgetright is offline   Reply With Quote
Old 06-03-2010, 07:15 PM   #3 (permalink)
i checked the spark and it was fine. how do you check the oil mix?
Old 06-13-2010, 11:06 PM   #4 (permalink)
no fear here's Avatar
Does it have an aftermarket carb? it could be the pop off is set wrong.
PJS Exhaust & Waterbox
38mm Keihin
R&D Reeds, Cages & Stuffers
Skat 15
R&D Toploader Scoopgrate
Ocean Pro rideplate
Pump drilled for dual cooling
500gph rule
Old 06-16-2010, 08:33 PM   #5 (permalink)
mgendron4552's Avatar
Water in the tank
pull tank out
drain
clean
refill
mgendron4552 is offline   Reply With Quote
