Old 06-05-2007, 11:03 PM   #1 (permalink)
rweller13
Default 750 SS issues
I have a 92 750 ss that runs great for about 45 min, then starts to loose all power. it's kind of stranger because the motor will never cut off it just will bog any time you give it gas. If I let it sit for a couple of hours and then try it again it's fine for about another 45 min. I've replaced the plugs, cleaned the carb, replaced all seals and diaphram in carb, flushed the cooling system, and replaced the fuel tank check valve. what could possibly be going on with this thing?
rweller13 is offline   Reply With Quote
Old 06-09-2007, 08:46 PM   #2 (permalink)
JUST-IN-TIME
JUST-IN-TIME's Avatar
vapor lock
check fuel and fuel lines
TRUE JACKASS FISHING REPORTS
Old 06-18-2007, 01:37 PM   #3 (permalink)
lemaster63
Default It may be overheating
I've never had the problem but I read that if it overheats it will automatically throttle back so you can head to shore. Perhaps after 45 minutes it has cooled enough to run properly. Check the cooling and make sure nothing is clogging the line.
Hope this helps.
lemaster63 is offline   Reply With Quote
Old 07-19-2007, 01:07 PM   #4 (permalink)
750ss
Default Did you fix it?
I have a 93 that does the same thing. What did you do to fix it?
750ss is offline   Reply With Quote
vB code is On
