91 550sx fuel problems - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
post #1 of 5 (permalink) Old 05-15-2017, 02:04 PM Thread Starter
Hi,
I'm having some trouble with my 550sx.
When I was riding the other day, I stopped to take a break and afterwards I was unable to restart the ski. It didn't bog down while riding!
Once home I started to investigate:
- I have spark (nice blue ones)
- I have compression 125psi and 120psi
- The fuel reaches the carb (i have installed a clear line and I can see it sucking up fuel)
- It starts if i pore some gas straight into the carb and then dies 10 seconds later. In those 10 seconds it responds to the throttle as nothing is wrong.
Since I thought it must be the carb i orderd a rebuild kit. Still this makes no difference.
I also used fresh fuel as i thought there could be water in the tank.
I have now come to the point were i need some advice, I was hoping to get it here.
Anyone who can help me ?
Thanks!
RobinL is offline
post #2 of 5 (permalink) Old 05-16-2017, 05:36 AM
Garage
Sounds like no fuel is getting past the inlet screen or needle valve is stuck. Did you change the screen and blow all the circuits out ?
rodsatheart is online now
post #3 of 5 (permalink) Old 05-16-2017, 03:00 PM Thread Starter
I cleaned the inlet screen and replaced the needle when I installed the rebuild kit. Today I noticed that the spring that came with the rebuild kit is a bit stiffer than the one I replaced.
I will try again with the original spring tomorrow.
RobinL is offline
post #4 of 5 (permalink) Old 05-16-2017, 06:05 PM
Garage
That spring sets the pop off pressure and should only be changed if the pop off is wrong or the spring is lost, then must replace it with the same color spring and verify the pop off.
post #5 of 5 (permalink) Old 05-17-2017, 04:05 PM Thread Starter
I used the old needle and spring and at first it didn't work. Then i bended the float arm a tiny bit and now it seems to work perfectly. Thank you for steering me towards the pop off valve !!
RobinL is offline
Human Verification
