Your water lines all look to be run properly and are the proper size.
The water flush that you have posted the link to will work perfectly for you. Install it in the line between the head and the exhaust.
The sand in the cooling chamber of the exhaust would indicate to me that the ski was probably run up onto a beach with the motor running, or the guy who owned it last rode it in the surf close to shore.
When it comes to flushing the ski always start the motor first, then turn the hose on just a trickle so you see it coming out the pisser on the side of the hull. Turn off the hose when done, then kill the motor.
Hope this helps.
