kaw zxi 900 low compression??? - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-17-2010, 11:46 PM   #1 (permalink)
Default kaw zxi 900 low compression???
i bought a 1995 900Zxi jetski that needs carbs but i decided to do a comp. test 1st just with the starter turning the engine i get 95,100,100 psi... is that horrible should i cut my losses or cont with the carb work
Bleys is offline   Reply With Quote
Old 07-22-2010, 12:31 PM   #2 (permalink)
Default 900 zxi low compression
I recently bought a '95 900 zxi machine. Prev owner ran a comp check right before my eyes with a screw-in tester. Read 96 lbs, nearly identical on all cyl. At home I repeated the test with 2 different hand-held gauges, and got 114 lbs on one, and 119 lbs on the other... again nearly identical readings on all 3 cyl. The book value is 121 lbs new. My machine runs great... it will nearly throw you off the back on aceleration. I don't know which gauge is most accurate, but it is good if all 3 cyl read close to the same. Good luck.
Old 08-11-2010, 01:10 PM   #3 (permalink)
make sure to hold your throttle open when your cranking it, it makes a huge difference
pistonslap is offline   Reply With Quote
Old 08-21-2010, 01:10 AM   #4 (permalink)
no not bad kawasaki motors run lower like that idk why but they do as long as the numbers are about 85 pounds or more on a kawasaki jetski motor and are not more than 10 to 15 pounds off from each cylinder your good...
kawasaki650sx is offline   Reply With Quote
