There is a siphon bilge on that machine. It is connected to the reduction nozzle through the hull. As water passes through the reduction nozzle it creates a vacume that draws water out of the hull. Inside the hull at the bottom rear near the driveshaft is a small white box, this is the pickup for the bilge.
These motors will keep warm for a while, nothing to worry about.
No oil in the motor except for the 2-stroke, mixed in the fuel or injected.
