OK, the ski is only running on cylinders 1 & 4, 2&3 are not firing. Didn't have time to pull plugs to see if getting fire. cyl 2&3 run off one coil, 1&4 off the other. Can you just swap the pug wires to the other coil to check to see if it is the coil or will it be out of time?
