help ultra 250x not starting no ignition - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 09-07-2010, 10:31 AM   #1 (permalink)
Default help ultra 250x not starting no ignition
HELP !!!
my ultra 250 has no ignition. when immobilizer key is pluged in nothing happens,is there a fuse or relay that could be blown if so where looked and cant find one,the battery is full power but nothing....any ideas!. Urgent want to use the ski.
brad j is offline   Reply With Quote
Old 09-08-2010, 11:29 PM   #2 (permalink)
I just bought a 2008 stx15f that would die on the guy on the lake and then would restart. When I got it home it would not start and had no spark.Also the display was bad and while monitoring the "switched" power for the display my voltage would drop to near 1 volt when starting.The orange ignition switch was bad. I took it apart (has screws) and discovered that the springs that put tension on the contacts had rusted and were not preloading the contacts.It seems the springs are not stainless steal so if water intrusion occurs they will fail. I cleaned the contacts,swiped some electrical grease (lightly) on them , installed some new springs,and it started right up and has never gave any problem.
frosty2 is offline   Reply With Quote
