97 STX1100 starting issue
So went to go and ride the ski about an hour after my daughter had rode it previously, pushed the start button, nothing, dead.
Symptoms: Push start button, display goes blank while holding down start button, does fresh reset upon letting off green button. If you hold down red kill button display does not blank.
I have confirmed via meter that the battery is at about 12.8 volts, and upon pushing either button, voltage does not change. I have reached in with a screwdriver and jumped across the hot lead to the start lead and get the starter to turnover.
Is this the start switch or the solenoid? I did notice a little moisture when I removed the cap over the fuses. I have not removed the cover to the whole electronics unit yet.
Suggestions/Thoughts?
