97 1100 STX flushing. Kaw plumbing su..s (does not work) - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 04-11-2011, 11:26 AM   #1 (permalink)
Default 97 1100 STX flushing. Kaw plumbing su..s (does not work)
On my STX, flushing with the hose connected to the factory fitting creates an air lock and prevents flow thru the head and a good flush (I run in the bay and need a good flush). This weekend I cut into the cooling line from the pump and flushed it that way and it worked great, head stayed cool and I was able to flush long enough to do some good. I will install fittings that will make it easy to flush this way from now on. I had cleaned all the water jacket cooling passages when I had the top end apart is why I am sure it is an air lock issue.
sbklf is offline   Reply With Quote
