98 Kawasaki ZXI 1100 Trim Doesn't Work - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-13-2011, 02:23 PM   #1 (permalink)
jgny1's Avatar
Default 98 Kawasaki ZXI 1100 Trim Doesn't Work
I am looking at a Kawasaki ZXI 1100 this weekend and the owner says the trim doesn't work. Any ideas what I can look for to try to get it working since i am 90% sure I am going to buy this one? Thanks in advance for any help.
jgny1 is offline   Reply With Quote
Old 05-14-2011, 06:04 AM   #2 (permalink)
did you buy the jetski?
martyc1976 is offline   Reply With Quote
Old 05-16-2011, 07:46 AM   #3 (permalink)
jgny1's Avatar
Yup, pick it up wednesday.
Old 05-16-2011, 03:16 PM   #4 (permalink)
i have the same problem with the kats.any idea what it is? cheers
Old 05-16-2011, 11:12 PM   #5 (permalink)
YamaDoo's Avatar
The Zxi skis had a design flaw of the KATS system. The electrical box housing the trim motor sits on the bottom of the hull where water flows. Water gets in and boom, it's fried.. VERY common on these watercraft. I am pretty sure you have to replace the whole box but I'd call a Kawi dealer and ask them if perhaps just the motor can be replaced.
Old 05-17-2011, 08:15 PM   #6 (permalink)
First make shure that the small black wire is on the negative side of battery. That is what my problem was.
bass547 is offline   Reply With Quote
Old 05-23-2011, 01:48 PM   #7 (permalink)
i have checked that and it is bone dry.very clean.is there any way to test them with a meter? ta
Old 05-23-2011, 01:50 PM   #8 (permalink)
yes i also checked the wire and its ok.when should the kats light go on ?
Old 05-30-2011, 02:00 PM   #9 (permalink)
Bass547 where exactly does that little black wire go. Well I know on the negative terminal but does it just go into the wiring harness or does it go to where the trim motor is located?
Joshbiz is offline   Reply With Quote
