94 750xi ss engine problems!!!HELP
I have a 94 750 xi ss twin carbs. When you pull the back spark plug out it starts and runs, when both are in will not start.. both plugs are firing. when front plug is in and is running motor sounds smooth. however when the other plug is in too the motor has a knocking sound when trying to turn over. any suggestions?
