Kawasaki STX-15F 2008 fuel warning light on - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 05-28-2011, 06:02 AM   #1 (permalink)
Default Kawasaki STX-15F 2008 fuel warning light on
Kawasaki STX-15F 2008 fuel warning light on! Please help it keeps going off until I hit the mode button. It shows a full tank when I first start the PWC but than quickly drops to empty and the fuel warning light goes off with a full tank of gas.
Any ideas?
mcmurtrey is offline   Reply With Quote
Old 05-28-2011, 06:45 AM   #2 (permalink)
Outlaw's Avatar
Arrow
If all other electronics are good to go more than likely it is a bad fuel sensor....JMO
2009 RXT-IS 255 HP
2008 GTX 215 HP
Old 05-28-2011, 09:03 AM   #3 (permalink)
Ok great, is that something I could swap out myself?
Old 05-28-2011, 05:54 PM   #4 (permalink)
Outlaw's Avatar
Arrow
No help there, I don't wrench on Kawasakis
2009 RXT-IS 255 HP
2008 GTX 215 HP
Old 06-04-2011, 07:53 PM   #5 (permalink)
Default Stx Display
Hi i had a simlar problem My display showed low battery even with a new one fitted and keep changing between fast and slo mode while running
I found display gets water inside shorting connections
Kawaski Usa are awhere of problem a seem to support customers kawasaki australia donnt help
Display is $600_1000 aud You need to be extemly carefull when washing not to spray display and the dealer told me if you flip ski water will get in no warranty as it will log a tip code to ecu make shore if you flip you remove meter remove rubber bung and clean any water out you can clean with isobolic alcahol or metolated spirts leave to completly dry before re install
johnstx15f is offline   Reply With Quote
