91 JS550 Bogs under throttle - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-13-2011, 07:36 AM   #1 (permalink)
Default 91 JS550 Bogs under throttle
I have seen some other posts similar to this. The ski has been in storage for 2 years, the last time it was used is when the problem had started.
I have taken some advice and just did a complete Carb Rebuild.
The ski fired up right away and ran smooth with the Hose running. I noticed some air bubbles coming from the Exhaust Pipe Gaskets (Top znd Bottom) and have ordered replacements. I also noticed smoke and air bubbles coming from the neck of the pipe on top of the stock waterbox where the metal pipe and fiberglass meet.
Based on everything I read the Carb and Exhaust seem to be the likely cause for WOT bogging when the ski is in the water.
Does this make sense?
I was going to order a replacement Waterbox but was wondering if anyone could confirm all I need to do is use fiberglass repair and wrap the top metal pipe where it meets the waterbox to solve the air leak?
webvation is offline   Reply With Quote
Old 06-13-2011, 11:44 AM   #2 (permalink)
p10sdad's Avatar
Those do sound right, also take a look at your reeds. Just a little fray on those can make it run really bad. Any little cracks, or frays replace those, they are not to expensive for some real nice carbon fiber, or v-force. I prefer the carbon
