Need HELP! - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-15-2011, 11:42 AM   #1 (permalink)
Default Need HELP!
So I cant find the answer anywhere..I just bought a 900 STX from a guy yesterday and he said I needed a battery. Well, I went out and bought a new battery and charged it and everything and put it in. STILL nothing. I dont even get lights on the instrument panel. No nothing, no clicks, no lights.
I have checked the fuses and they are good.
Also, another question, where and how to do I hook up a hose so I can crank it?
BTW, this is my first watercraft of my own.
Chris Grigg is offline   Reply With Quote
Old 06-15-2011, 11:59 AM   #2 (permalink)
you have to have a special adapter to put water to it....its a little hose from the bulkhead inside the hull...youll see it...its a line running to the block from the impeller...
Welcome to Kawasaki.com go to this link for the owners manual and the maitnence book....very helpful
dirtydave916 is offline   Reply With Quote
Old 06-15-2011, 12:18 PM   #3 (permalink)
Where do I get the adapter to hook to it that screws on the hosepipe?
Old 06-15-2011, 12:29 PM   #4 (permalink)
that idk...what i do is put a hose in the intake grate and fire it up...point it twards the impellar tho...
Old 06-15-2011, 03:47 PM   #5 (permalink)
I am not familiar with your ski since I just got my first two ski's and haven't even gotten all the problems on mine fixed yet...so have yet to see any water. As far as the starting problem I can tell you what I found on one of mine. Water had gotten into the electrical box and ruined the starter solenoid. Even without having the display showing it would turn when I jumped the posts on the solenoid so I knew that was part of the problem. also, I found two wires that had corroded inside the quick connect couplers and after fixing those I got my display and all lights working. Don't know if this will be any help to you but it's worth checking...only takes a few minutes to look. I hope you have better luck with getting information on this site than I have had so far...haven't had one response to my post on the problem I am having with my 1100 STX.
TXEasyrider is offline   Reply With Quote
Old 06-15-2011, 03:54 PM   #6 (permalink)
Outlaw's Avatar
Arrow
Unfortunately, not many members are big Kawasaki fans. There fore know very little about the line . Like me for instance, Try the GREEN HULK forum
2009 RXT-IS 255 HP
2008 GTX 215 HP
Old 06-16-2011, 06:41 PM   #7 (permalink)
I found the problem. The negative from the battery was not properly grounded. I replaced the negative and made a custom one and it turned over just fine. I needed to spray some starting fluid in the motor, but it runs great!
Old 06-16-2011, 06:56 PM   #8 (permalink)
Outlaw's Avatar
Lightbulb
Congrats good job!!!
2009 RXT-IS 255 HP
2008 GTX 215 HP
Old 06-16-2011, 06:59 PM   #9 (permalink)
Thanks.
