Ill put my 2 cents in. If you have a running ski try swapping the battery and starter to the problem ski. Then double up your ground wire that goes from the block to the cdi box. Make sure no corrosion on starter wires. And also im confusd if its running on land still. Half way through it seemd like you said it wasn't doin that anymore. But anyway try that. Also my 440 started doin this when the rings went bad. It held comp but when u put a load to it it got blow by
