Ethanol Gas
Stay away from ethanol gas especially when the equipment using it sits around for week at a time.
Ethanol gas is only stable for around 100 days; after that, it begins to phase out of the gas. The ethanol is very hygroscopic (picks up water rapidly). It is also a solvent that will destroy rubber and plastic gas line, floats, and other engine parts.
You may have water in your carburetor or small rubber pieces in your gas filter, who knows.
Try draining your carburetor bowls to get rid of any water thet may have settled there and change your gas filter.
In the future, when you know you will have a long storage time, use non-ehtanol gas or get the additive that can be used to counter-act the ethanol problems.
