When you drive a ski in shallow of water, there is a danger you will draw up sand, stones, and other materials into the pump. When this happens, you can kick the rpm's up but travel very slow. To try and clean the pump out, you can rev the engine and let off; keep doing this many time and it will usually clear. You will feel yourself going a little faster each time you rev when it starts to clear.
I have never pulled any stones up into the pump but I would say this could possible put a hole in the hull allowing water to fill it?
Maybe you just forgot to close the drains before you put the ski into the water? Lets hope so!!
Have a great day!!! {:O)
