1993 Kawasaki 550sx problem
I've got a 1993 Kawasaki 550sx that runs for 10 minutes then dies out of the blue. If you try again an hour later it will run for 10 minutes then die again. The process just repeats itself. The compression in the cylinders is good (160 psi each) and the ski has new plugs and a new battery but the problem is still there. Any ideas on what it could be?
