How hot is "Hot"??. The pisser water does run hot to the touch, but it shouldn't be sputtering with steam. After a run, you should be able to put your hand on the heads, cyclinders and exhaust pipe. It will be hot, and you won't be able to hold your hand there very long... but it should NOT scald you. Drizzle water on it... does it sizzle?
That said, maybe you disturbed something in the exhaust pipe when you fixed the threads. Cooling water flows from the pump, into the lower exhaust manifold, thru the jugs, out the head, into the pipe(just the water jacket shell on the pipe). At that point, some exits the pisser, and some enters the exhaust gas flow itself. If that last part is blocked, the small orfice on the pisser won't let adequate flow get thru the jugs.
On the hose, the pisser water never went thru the jugs... engine heat actually gets reverse flow and exits thru the rear pump so it probably does run a lot cooler.
