no spark 93 JF650-B5 - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-13-2011, 07:33 PM   #1 (permalink)
Default no spark 93 JF650-B5
I am looking into buying a 93 Kawasaki JF650-B5, when I went to look at it it wasnt getting any spark to the plugs. Does anyone have an idea what could be a common issue or a way for me to track down the cause.
mudslide311 is offline   Reply With Quote
Old 07-27-2011, 08:45 AM   #2 (permalink)
i had the same problem and what i found was to test any of the wires coming back from the stator to the ground and make sure that you are getting power back from the stator . . if you are then check the wiring . but if you are not they i would check the stator and make sure that it looks arlgiht. (the stator is located in the front of the engine block . . it is held on by 7 10mm bolts
Cokedog32 is offline   Reply With Quote
