mix ratio help
We just brought home a sxr800 the other day. The person we purchased it from apparently doesn't know anything about the ski and represented it as a stock motor. The compression is high (225). If you run a stock motor I believe the mix ratio is 60:1. What would you run in a high compression motor. Until we figure out what's inside we'll probably run a 50/50 mix of race gas and 91 pump gas.
Opinions? Thanks,
Ken
