650sx cylinder removal - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 07-31-2011, 06:12 PM   #1 (permalink)
Default 650sx cylinder removal
Hi i just recently purchased a 1990 650 sx. the ski was not running so i decided to take out the motor and rebuild the top end. everything was going well until i was not able to separate the cylinder from the shortblock. i removed all 8 nuts holding the cylinder on and this thing will not move. Even put it on a engine hoist with some straps trying to pull the pieces apart. Im stumped.... Any thoughts suggestions?.... Am i missing any bolts?.. What should i DO?!/? HELP!
Scott650sx is offline   Reply With Quote
Old 08-09-2011, 11:38 PM   #2 (permalink)
no fear here's Avatar
soak all the studs with WD40 and I mean drench them. The aluminum corrodes and builds up around the stainless studs. It takes time and patients.
Also try heating the area around the studs with a small propane plumbers torch, and gently tapping with a hammer.
PJS Exhaust & Waterbox
38mm Keihin
R&D Reeds, Cages & Stuffers
Skat 15
R&D Toploader Scoopgrate
Ocean Pro rideplate
Pump drilled for dual cooling
500gph rule
Old 08-12-2011, 10:58 PM   #3 (permalink)
Awesome thanks for the advice i will try that tomorrow!
Old 08-13-2011, 01:18 AM   #4 (permalink)
i had to use a slide hammer on my 750 just lightly tap up on each side and it will come up, i would not however heat anything up and hit with hammer
Timmay is offline   Reply With Quote
