1987 Kawasaki JS300 Rebuild - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-03-2011, 10:12 PM   #1 (permalink)
Default 1987 Kawasaki JS300 Rebuild
I just picked up a 1987 Kawasaki JS300 locally for $100. The hull is sitting in my yard and the engine is in my garage. I plan on doing a full ground up rebuild. I am going to try to keep a photo log and update this as I make progress. Also, does anyone have any suggestions for this rebuild or have any experience doing one? Thanks!
Thrilliot is offline   Reply With Quote
Old 08-04-2011, 10:06 PM   #2 (permalink)
Took a scrub brush and some water mixed with a little degreaser/general cleaner to her today for about 2.5 hours. Doesn't even look like the same machine anymore. Still need to compound out some spots but the gel coat held up amazingly, no cracks only a few scratches from the previous owner.
Old 08-05-2011, 09:28 AM   #3 (permalink)
p10sdad's Avatar
I wouldn't waste my time or money on a 300. I think once you get it on the water, the performance your going to get out of a 300 is not going to be what you. Since you already have though, as long as the crank spins, I would just put in a new battery and piston kit, and then sell it. You might be able to get 500 for a running 300. Just my 2 cents, but if you really want to keep it and rebuild it, we'll help walk you through it
Old 08-05-2011, 02:53 PM   #4 (permalink)
I'm going to rebuild the 300cc engine and get everything on the ski 100% and then hunt for a 550cc to build up to swap into it. It will be a nice variation of learning from my 16' Baja
Old 08-05-2011, 06:33 PM   #5 (permalink)
Stripped the exhaust manifold and muffler assembly off the engine today, had to cut the tops off two bolts that got stuck in the elbow while taking it off the manifold. Soaked them all in degreaser and cleaned out the water jackets as best I could. Other than that everything went smooth with a little help from PB Breaker. The head is another story though, got all the nuts off but its still not budging. I've been giving it a shot all around of PB Breaker every few hours or so to hopefully loosen it up. From what I can see through the exhaust port though, the piston and rings look great.
Old 08-06-2011, 08:17 PM   #6 (permalink)
Pulled the cylinder off the crankcase today and removed the carburetor from the crankcase. The cylinder head is still stuck on the body though and I can't manage to pry it off and don't want to damage the head, anyone have any ideas? I've basically soaked this thing in PB Blaster and it still won't budge. The cylinder had some dirt and other grime on top so I gently scraped off as much as I could making sure not to nick the surface. It looks much better now. Cleaned the rings, they looked great too. The reeds inside the reed cage looked phenomenal too, not bent at all. They were nice and tight to the cage.
Old 08-12-2011, 06:10 PM   #7 (permalink)
jonesy54's Avatar
that's a good looking hull you got to start with. I'm surprised how well it cleaned up.
I like that old Jeep Wagoneer in the background too.
-1990 X-2 - the weird one
Old 12-22-2011, 12:36 AM   #8 (permalink)
How has this project gotten on?
sectrew is offline   Reply With Quote
Old 12-24-2011, 08:28 AM   #9 (permalink)
98yota's Avatar
Your ski looks great! I've always thought one of those one lungers would be a fun project. Keep up the good work!
1993 Yamaha WaveBlaster 701
1989 Yamaha WaveJammer 500
