'95 750zxi with oil in crankcase - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 08-21-2011, 01:37 PM   #1 (permalink)
Default '95 750zxi with oil in crankcase
I am redoing the top end of my '95 750zxi due to low compression in the front cylinder & have a question. I got the jugs off & when I look down into the crankcase, there is about 1/8"(or maybe less) of oil at the bottom. I sampled it on a clean paper towel & it seems to be unburnt oil with no sign of water. Should I do my best to remove it or leave it be?
Thanx
Mike
Livermore, CA
bugyboi is offline   Reply With Quote
Old 08-22-2011, 10:47 AM   #2 (permalink)
you nedd to disassassemble the bottom end and clean it. you dont want any debris to reach the bearings in the crank.
Old 08-22-2011, 01:43 PM   #3 (permalink)
You didn't tell us the history of this ski. The oil residue could be fogging oil from recent storage. It could be wash-down oil from attempts to put oil in the plug holes to free up seized piston (low compression cause ???) If you are going to do a re-build, you don't want to leave anything unchecked. If there's no bottom end damage, all it will cost you is some gasgets... check it all out an re-build with confidence. Put a block-off plate on that crankcase drain while you're at it.
