Installing a supercharger belt on a 260x?
Trying to put a new supercharger belt on my 260x that is broken. I have a service manual and it says to remove the engine mount bolts and slide the engine forward. Is this what you guys are doing? Is there a way to loosen the coupler from the driveshaft for the pump and install it that way? I have the pump out, but there is about 1/2 to 1" more clearance needed to slide the belt through there. Is there an easier solution or should I just pull the exhaust off and slide the engine forward after loosening the engine mounts.
