Welcome to the forum! You might need to prime the fuel lines. Sometimes the pump doesn't have enough pull to get past the air bubble in the line. I would put the inlet line into a cup of fuel and see if the pump will funtion. If not the pump might need a rebuild, kits are usually 15-20 bucks so they won't break the bank. Change your fuel filter. Make sure the impulse line is not cracked or pinched. Give these a shot and let me know. Good luck!
1993 Yamaha WaveBlaster 701
1989 Yamaha WaveJammer 500
