96 SLT 780 water in hull after riding - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 10-30-2012, 04:45 PM   #1 (permalink)
Default 96 SLT 780 water in hull after riding
I am getting water in the hull after riding the ski. It does not get water in the hull by just sitting in the water, just after riding. I'm thinking the drive shaft seal?? Any ideas on what to check, or how to change the drive shaft seal would be greatly appreciated! Thanks.
iflyp3fe is offline   Reply With Quote
Old 11-01-2012, 06:52 PM   #2 (permalink)
You need to make sure it is not leaking from the cooling system while it is sitting still in the water running. If the drive shaft is leaking this should also happen when sitting still or idling (just maybe not as much as it does moving faster).
If it is the drive seal, I would try just adding more marine grease through the grease point with a grease gun first. If that doesn't stop it, then you are probably looking at replacement and $$$. Good luck.
johnh is offline   Reply With Quote
