The drive shaft seal is located in the engine compartment.Behind the engine is a shroud secured by a hose clamp.That clamp is on the seal/bearing assembly.
Another leak point is the plastic fitting located behind the seal/bearing,where the hose attaches,it could come loose.It threads into the hull.
If you have any other Polaris questions,go to greenhulk.org
