Engine Problems - PWC Forum: The best hang-out for Personal WaterCraft enthusiasts
Old 06-03-2008, 12:20 PM   #1 (permalink)
Default Engine Problems
i have a 2001 polaris genesis 1200 and im having so engine problems. i can start it up when it is cold and it will run for a little bit until i hit the gas and then let off and then it dies. i pulled the plugs and they were all wet so i changed them out because i thought they might be on the way to fouling out. after i changed them it started right up and did the same thing. i pulled the plugs again and they were all wet agian. Have any ideas? maybe i need to rebuild the carbs? adjust something? what do you think?
genesis1200 is offline   Reply With Quote
Old 06-14-2008, 09:06 PM   #2 (permalink)
So.....you can't speed up? Or after you speed up, you idle down and it dies on you? Good bet it is carb or fuel pump related. Try changing the fuel selector switch. Check for water in fuel.
