Gensesis ficht dieing
99 polaris genesis ficht. after engine heats up it dies like no gas or spark. TPS has been replaced. checked stator windings at emm plug and got about 1.8 to 2.0 ohms which is high. checked stator cranking voltage and got 6.8vac on 1 and 2 and 4.6 on 4, 5, & 6, which is just a hair low, but battery is at 11.6 vdc. checked voltage at injectors and got 32 vdc on each injector with engine running on the other two cylinders. I really need some advice. Any help will be greatly appreciated. Thanks.
