Mine did the same thing when I tried to start it , just went click the relay is good. its the sarter one way to test it is to back the motor up! should be a cover that you need to remove on the drive shaft that has a greae zerk on it .
Then turn shaft , hit the start and should turn over if stops after you do this then you need a new starter . Thats my problem its under the motor, So Iam taking it to the dealer to fix, found one on line for 74.95 labor is 300.00
